Hi,
I've got a 15' Polar Kraft Bass America, with a 50HP Johnson. I've tried lowering the engine all the way down, to up as far as it will go, and it porpoises anyway I try it. There is no storage in the front to put any sandbags or anything, but it does this with the trim all the way down with only 2 average size people (one being the driver). I can't use the trim at all, or it gets worse. I was wondering if someone that is pretty experienced with this kind of thing could tell me if smart tabs would correct this problem? I know they're only a little over $100, but I don't want to spend anymore money trying to fix the problem unless I know if it will work more than likely. I've never rode in a fiberglass boat before, I've only owned jetskis in the past, so I don't know if this is a common problem with this aluminum type hull on these particular models, and nothing will correct it.
