Port engine surges. Sb is fine
crestapre
I have twin '94 5.0l Fords attached to SX drives.
I'm having a problem with the port engine surging at RPMs over 2500
She will run fine at times, then loose power, and surge over the RPM I was originally at.
I've changes the fuel/water filters 3 or 4 times this season.
I've put a tube into the fuel tank and pumped out some water. Not much.
The fuel pumps (high and low pressure) have also been replaced this year because they were making noises and getting hot.
