artysniper
- Joined
- Jan 4, 2010
- 21
i have a 2000 johnson 90 v4 , , just purchased the motor,the motor looked like it was sitting for a while i had a mechanic change the water pump , and rebuild the carbs . now i get home and run the motor on muffs, starboard side is cool port side is getting hot . is it because its not in the water or should i remove the head . pee stream seems week compared to my 96 ocean runner . water pressure gauge is reading mabey 1 lbs at idle . is this normal .and what should max water pressure be at wide open throttle. thanks .
