portable a/c units
Cptkid570
Ensign
Hey everyone,
I?m contemplating different cooling ideas for my 26 foot older sea ray sundancer (1985). I?m trying to do it with the most minimal $$ as possible and came across the portable air conditioners that they have out these days: http://www.walmart.com/catalog/product.do?product_id=5402975
This product looked interesting because:
1. It can sit inside of the boat as it doesn?t drip water and the exhaust hose can just be put up to a window.
2. It?s cheaper than the cruisair carry on marine a/c units and doesn?t hang into a hatch.
3. My other option was to get a house window a/c unit and make a cover on it so that it pipes the air into the hatch (once again, this one wouldn?t require me to pipe the air in through the hatch).
At $300, it?s only like $200 more than a cheap window unit.. and is way less than a cruisair carry on.
It?s 7000 btu and I looked at the power ratings in comparison to a window unit a/c at 5250 btu
Portable a/c 7000btu:
Voltage ? 115V
Amps Cooling ? 8 (doesn?t say what the start up amps are)
Watts Cooling - 900
General Electric 5250btu window unit:
Voltage ?
Amps cooling ? 115v
Amps cooling ? 4.6
Watts cooling ? 490
Are these figures very close? What size generator would be required to run the portable a/c? I believe the 5250 btu could be run with a Honda EU2000i?
From what I?ve read, the portable a/c units don?t cool as efficiently as the portable units, but I feel that you are going to lose efficiency on a window unit by piping it in through a hatch, so I?d probably feel that the 5000 btu window unit and 7000 portable unit would cool about the same..
Just looking for alternatives (inexpensive alternatives) to mounting an a/c unit in the hatch.
Let me know your opinions....
jeffnick
Re: portable a/c units
We run an R2D2 unit in the van with a Honda EU2000i.
And you are correct - if they have a single exhaust hose these units are not true air conditioners, they're spot coolers. There are 2 hose units available which are true air conditioners.
There's another option if you're a little handy; runs on a Honda EU1000i.
http://www.geocities.com/jeff_nicholas/AirConditioning/Air1.html
or a rooftop unit w/ 2000i?
JCF350
I use a small window unit for weekend trips. Set the hatch lid edge on the unit and use a sleeping bag to cover the gaps. More room in the cabin and no duct work to fool with. The EU2000i Honda will run it.:)
tashasdaddy
remember, these generators are not coast guard approved.
JCF350
Do they have rule prohibiting one? Don't know personally, just don't remember hearing or reading of one.
As far as exhaust gases goes I place the genset in the path of the A/C condenser output on the bow. Dang sure ain't gonna run it overnight.
Cptkid570
Ensign
Jeffnick - you are able to run an 8000 btu window unit with a Honda EU1000i? I would think that you'd need the EU2000i to run a window a/c unit...
I stopped by home depot and looked at the "portable" a/c units. They are much larger than I thought and would probably take up too much room on the boat... so, I'm back to the idea of using a window a/c unit.
jeffnick
Yes, the 1000i would start and run a WalMart 8000BTU air conditioner, but the generator had to be OFF eco-throttle and the air conditioner fan had to be running on high before the compressor was switched into the circuit.
On the other hand, the 9000BTU R2D2 unit totally requires a 2000i and occasionally the generator will even fault out while trying to get it started.
We've upgraded to a 6,000 BTU which we run regularly (all night on the boat) with the Honda EU1000i and never a problem of any kind even on eco-throttle.
Cptkid570
Ensign
I already have the a/c unit. I think it's 5250 btu's. I may be stopping by the Honda genterator dealer some time soon and compare the EU1000 and EU2000 -- all I'd really need it for is to run the a/c. I'm sure they'd test each on my a/c. I have a 2200 watt generator that I could use for stuff at home (too loud for the boat - and too heavy to really carry around).
Which do you think would use less gass -- an EU1000 working hard to run the a/c or an EU2000 not working hard to run the a/c?
EU1000 says - "Eco-Throttle - Runs up to 8.3 Hr on 0.6 gal. of Fuel"
EU2000 says - "Eco-Throttle - Runs up to 15 Hr on 1 gal. of Fuel"
So the fuel economy seems comparable...
jeffnick
You're kidding, right?
If one or the other was 10% more efficient you might save 25 cents a day. If the 2000 was more efficient, with the additional initial cost (and more for oil changes) how long would it take to come out ahead?
I've got a 1000, 2000 and 3000 all Honda EU-i's.
This is how I look at them.
The 3000 is fixed - it takes 2 people to move it. It stays on the camper.
The 2000 is primarily to run the A/C in the van. I can move the 2000 around horizontally, but getting it on/off the boat requires a little planning.
The 1000 is a dream to handle...up and down off the boat, in and out of the cuddy, up and down off the transom -- a downright pleasure to jockey around, never requiring any consideration or forethought.
On the other hand, if you're a young muscleman, you could probably throw the 2000 around.
