portable gas tanks ... ????
coolbikeguy
hey guys has anyone used the [h=2]Attwood 8806LP2 Portable Fuel Tank ???[/h]
the attwood tank is 6 gal for $39.98 and the moehler tank is 6.5 gal for $54.01 .... any opinions on the 2 ?
MH Hawker
i have had both, i like the attwood better the moehler has a ridge in side for the extra 1/2 gallon and you have to lift and tilt it to use it
82rude
I believe that's on purpose MH. Its sort of a reserve .Could be wrong but on my 12 gallon moeller that's what it is.I have both a attwood and moeller 12 gal tanksand their both fine .The moeller is a low profile and the attwood is normal and they compliment each other perfectly.
David Young
I don't know if these plastic gas (6 gallon) tanks are like the one i bought from Walmart or not. With about a gallon and a half of gas, its flat as a pancake in the cool of the morning and blows up like a balloon in the heat of the day. It is sitting in my shed when not in my boat. My other tank is a factory metal 6 gallon one, and works perfect. :)
MH Hawker
thats due to the vent being closed
82rude
You will be waiting a year or two for your gas to evaporate.Mine is always opened all the time and is only closed during transport.
alanfox55
Could there be an issue with the gas attracting moisture in a gas tank with the vent open all the time? I would think not if the gas was used in a short period of time but how long before it could become a problem?
David Young
I rebuilt my leaky 6 gallon omc metal gas tank. I now have two omc metal gas tanks, i'll keep the plastic tank as an extra and fill it if i decide to take a longer trip on my boat. Until then it will stay empty :)
Silvertip
Stop worrying about fuel evaporation or attracting water. Leave the vent open and keep the tank out of the sun. It simply is not a problem.
GA_Boater
This is the best advice - Really nothing more than using common sense.
