massimofinance
- Joined
- Oct 30, 2004
- 508
Hi all: I need to buy a jump start/charger for my boat, PWC, ATV, tractor, etc. Basically, any application where I might be out away from power and need a jump (out on the water being the main concern). I noticed that these chargers run the full range, from $50 to $300. For my application, what do I need? Is the below fine or overkill? What Amps, volts, etc. am I looking for?<br /><br />Thanks,<br /><br />KK-Jump-N-Carry® 660 Battery Booster- 12 Volt, 1700 Amp ($120)<br /><br />The K&K Jump-N-Carry® series establishes the standards by which other jumpstarters are judged! Intended for frequent professional use each lightweight portable unit is extremely versatile and easy to use. The Jump-N-Carry® Pro 660 delivers 1700 peak amps of raw starting power and weighs only 18 lbs. Pound for pound the Jump-N-Carry® Pro 660 is the most powerful jump starter on the market. <br /><br />Specifications:<br /><br />Peak Amps: 1700 <br />Voltage: 12V <br />Battery Type: Sealed Lead Acid (AGM) <br />Battery Capacity: 20 Amp Hour - High Performance <br />Cable: #4 Gauge Welding 46" long <br />Charger: 500mA - Built-In Charger <br />Indicator Display: Volt Gauge <br />Unit Weight: 18 lbs.
