- Joined
- Jul 18, 2011
- 18,477
I have been thinking about the idea of positive flotation for my new (to me) boat and wanted to see if anyone out here in iBoats land has dealt with this in the past. (nothing really comes up in the search pertaining to ‘bigger’ boats . . . )
My previous boat (Formula 242) supposedly had “Positive Flotation” per the product literature, but my ‘new’ boat probably does not, and the corresponding literature is a bit vague. My ‘new’ boat – Formula 330SS - has “foam filled chambers” along the length of the hull and foam up under the cabin floor, etc., but I am thinking that it is not enough to actually keep the boat afloat in the case of an ”unplanned event”. Bigger boats are generally ‘sinkers’, and I believe that my boat would sink as there is probably not enough flotation to keep it afloat.
I did some measurements and calculations:
( I used the weight of fresh water, even though I boat in salt water – slightly heavier)
Weight:
Boat weight = 8,900 lbs (per specs)
Fuel weight (max) = 160 gallons, so 160 gallons x 8 lbs/gallon = 1,280 lbs
Total boat + fuel = 10,180 lbs . . . add some people and gear . . . figure 11,000 lbs.
Buoyancy:
I considered the boat’s buoyancy in 3 aspects - (iron(engines), fiberglass, flotation). To be conservative, I figured everything that was not ‘engine’ or ‘flotation’ to be the weight of fiberglass, even though some of the stuff is lighter.
Engines = 2,000 lbs / 500 lbs/cu. Foot = 4 cubic feet
Fiberglass = 8,900 lbs – 2,000 lbs = 6,900 lbs . . . 6,900 lbs / 125 lbs/cu ft. = 55 cubic feet
I did some measuring of the foam compartments throughout the boat and figured them to add up to a total of 56 cubic feet.
So, total displacement if submerged would be:
4 + 55 + 56 = 115 cubic feet, 115 cubic feet x 62.4 lbs/cubic foot = 7,176 lbs
So, it looks like it comes up a bit short . . . 11,000 lbs – 7,176 lbs = 3,824 lbs
I would need about 3,800 lbs additional buoyancy. . . which would be:
3,824 lbs / 62.4 lbs/cubic foot = 61.3 cubic feet.
That seems like a lot, and not really practical to add to the boat. So, I am wondering if I goofed in the measuring or calculations somewhere. (I emailed Formula Tech Support to see if they have any more info regarding the flotation designed into the boat)
If it were a minor amount of flotation needed, I might consider adding some as there is plenty of space under the cockpit floor and in other areas. There used to be a company/product called “Yacht Savers” than sold inflatable bags to keep a large boat afloat during a crisis . . . but they went out of business. (Maybe those with big boats would rather have them sink. . . :noidea: )
Anyways, thoughts, ideas ??? maybe a life raft instead ??? :noidea: TIA.
Weight:
Buoyancy:
