1958 Johnson Super Seahorse 35hp RDSL-20<br /><br />Before I try this, I wanted to run the possibilty past the experts on this board. I am having starter troubles. In a previous post I was told to have it rebuilt. Today, I found a place that can do it, but I'm not convinced that is the answer. <br /><br />The problem is that the starter cranks extremely slow. I purchased a used starter which looks great inside (although so did the original once I cleaned it up), and installed it the other day. It is doing exactly the same thing that original one was ... slow cranking. To eliminate the possibility of bad wiring or a bad solenoid, I had been jumping directly from my car to the starter. With the plugs removed, both the old and the newer starters spin the motor great. With the plugs in (under compression)... slow cranking. I know that this motor has compression release when using the pull rope, but I don't think it has that with the electric starter. <br /><br />My brother suggested that there might be nothing wrong with either starter. He thinks that it's possible that the jumper cables cannot carry enough amperage to allow the starter to work at its full capacity. In round one with this starter problem, I only jumped from the car to the starter. The wiring harness was bad so I couldn't connect a battery. I've finished rebuilding the wiring harness except for new battery cables, but through the harness (jumpers directly to the old battery leads.. no battery installed ) ... I get the same thing. I suspect that my brother is right, and when I install the new battery cables and a new battery, the starter will probably work. I guess I'm looking for someone to agree, or tell me that I'm nuts, before I give this a try. Either way I'll need the parts for this, but I'm a long way from having the boat ready and that was going to be a later purchase.<br /><br />Sorry for writing a book, but there are lots of details and if this works, it might save someone reading these boards a lot of worry later. <br />Thoughts?<br />Tom
