mudweiser
- Joined
- Jun 21, 2007
- 115
The boat is a 89' Bayliner Arriva with a 5.0 and alpha 1 outdrive. The serial number begins with OC on the outdrive and engine. I rebuilt the outdrive and had a hard time installing it. It turns out i had to drop the front of the engine about 1/2" to get it aligned with an alignment tool. The hull is good and free of rot. Some people said my rear mounts could have bad rubber. Now i look it up on Microfiche and i don't see any rubber rear mounts, just the nylon washer. Was i correct or should this boat have the rear rubber mounts? I hate to reinstall the drive and there is a problem further up the line and it takes out another bearing and gear set.
