1991 Evinrude 150 Intruder
E150GLEIS With VRO2
I'm having some concerns about the fuel system on this motor. When I go to start it I pump up the bulb in the fuel line but it never becomes firm or hard. This has all new fuel line w/bulb and the check valves on the two fuel tanks are good. There is no fuel leakage anywhere and no fuel leaking from the carbs. I also have heard that the VRO pump could have an internal leak and should check the line going to the pulse limiter. No leak and dry also.
When starting I always have to pump the bulb about 20 to 30 times. The motor runs rough at idle or any speed up to 1/3 throttle. At idle it REALLY jerks around and will turn its self sideways, I keep a bunge cord on the steering wheel to keep it straight when starting. Above 1/3 throttle it smooths out and runs great. (It is a gas hog also, I know, its standard for this type of monster. It REALLY is thirsty) Two 18 gallon tanks in a few hours running under 3,000 rpm.
Any thoughts of where I should look, other than shopping for a newer unit?
E150GLEIS With VRO2
