What are the common leaking spots on Alpha 1 gen 2 that would cause some of the oil to be milky? I took my drive apart to change the impeller and some of the oil was milky but not a lot. So i am trying to figure out where the water is coming in. The water pump face seal is really torn and broken. I am guessing this is where the water is coming in? What else should i check.. Everything else looked visually good. I see that manual says that a special tool is need to put this seal back on, is it needed or what is the best way to get it back on?
Also, when i pulled the bottom half of the out drive, two little metal plates that look like half moons fell out. I know i have seen them before in the manual or somewhere, but what is the best way or proper way to put them back in. It was kind of weird that they just fell out.
Thanks a lot for the help?
Dean
95 Bayliner 3.0 mer Alpha 1
Dean
