Just bought a new prop for my 1990 Johnson 120 (spun the old one). Now every time I get the engine to 5400 rpms it feels like the prop is spun again. If I lower the rpm's a little it runs fine. It is also ok on hard accelerations. Do you think the prop is bad or is there a rpm limit on the engine causing it to cut out?<br /><br />Also, wrote in about a quickstart problem last week. Advice was to change/check the thermostats and diaphragm. Good advice, changed everything and no more problems.<br /><br />thanks again.
