Here's the story... I use my 87' 85hp Force as my duck boat transportation in big water w/ big loads. It has been pretty cold here in the 20s,30s, and bairly low 40s. There was snow on the ground since last saturday that still hasn't melted yet.
I ran the boat Saturday without a problem it was around 30 degrees. Got up early Sunday, it was 26 out. The boat fired right up, I let it idle a few minutes like always when it's cold. We took off and were a few hundred yards off shore when the temp buzzer started ringing. Killed the boat. Sat for about 10-15 minutes waiting for it to cool. Buzzer finally stopped, fired it back up and limped to shore.
A buddy of mine I've went hunting with for years always started his old merc up and if it wasn't pumpin water, he'd let it idle a few minutes, kill it, wait a few minutes, fire it back up and it would ALWAYS be pumpin (Seen it 40 or 50 times). We'll I thought the same. I fired it back up at the ramp (for the 3rd time) the exhaust ports were spittin water (like they always do). I thought maybe it was good. Instead of heading out, I did a few large donuts next to shore and the buzzer went off again. I figured I tried my luck enough and loaded the boat up and went home.
I saw the thread about the telltail a long time ago and never did it. Well I figure what better time than now. After a few runs to the stores it was done (very easy and a great write up btw... wish I would have been smart and did it long ago). Put the motor in a 15 gal tub... nothing. Left it idleing awhile... overheated again (buzzzzzzzer was ringing!). I'm not sure it was warm enough to unfreeze the possible ice inside. The lower unit was very cold where the pump sits... of course the exhaust a block were pretty hot.
So I'm stumped...
Questions:
1. I assume the impeller was froze up? (that sound right? If not, your guess to no water cause?)
2. What are the odds my impeller is still good after all that run time if it was frozen?
3. What is the best way to drain the water out of the motor so it won't freeze the pump for future reference?
4. Why does my force hate me... or is it the cold weather!!
Thanks in advance for your opinion/help!!
So I'm stumped...
Questions:
