Just bought this boat. 17 Ft Lowe fat bottom aluminum. 96 model. None of the accesories work, and the wire harness looks trashed. Wire nuts, Butt splices. Different size and colors all over. Motor runs and bilge pump works, trolling motor works (but seems weak) but thats it. Nav lights, live well, stereo all inop. Nav light sockets have 12 volts to them, and other pin is grounded. But there is a little under a volt coming from the ground pin to ground and lights don't work. I'm going to start with the toggles, under the dash, and then in the battery/fuel tank compartment. But if need be, is there a way to replace the harness under the flooring without ripping out the flooring? THAT little project is planned, but I want to get thru this summer first. You can zoom in to where the harness comes out of the floor.
