So I think
racerone nailed it.. LOL!!
Johnson 115 Model J115TLEOR
I went to look at the boat, and the thing runs NICE!
Strong spark on all 4 (7/16" gap checked).
Seller had a spark tester board that could do all 4 cylinders at once... Strong Blue and Snappy on all 4..
Compression tested too.. 120-125 on all 4.. Port side had about 120.. Starboard was more like 125..
Thought it was weird, but further research says that's pretty normal for one side to be lower (by a little) than the other.
Research also showed, that's pretty good for this engine.. Right?
Anyway, trim/tilt works, FWD/REV work, (Short lake test, and MAN the thing flies!! lol), LU gear oil sample was not milky and seller gave me shop name he used to ask his mechanic questions if I wanted.
So, I called and asked if there was regular service on it, or if was brought in often or not..
His records said yes, serviced regularly, and no.. Not brought in more than usual..
Rebuild was about 2 years ago..
Anyway, Bought the boat..
Engine alone I believe was just about worth the price, but add to that, decent hull, and a trailer..
When I got home, I noticed the fuel pump is not the VRO style, or OIS type fuel pump and seller was premixing, so I guess that's been converted already..
At least I thought the 95 115 had oil injection stock, but maybe not..
All said, not sure it was a "Bargain" per se, but certainly worth a bit more than I paid when you put it all together..
So after this rambling of mine, and thank you for reading..
Is there anything in particular I should be watching out for on this 95 115?
So far so good, and there are no issues at the moment, but any insights are more than welcome!
Lastly....
Lower gear oil... My 71 50 hp (first engine for me) of course needs Premium blend or Type "C" specific for electric shift.
This 95 115 does NOT need that..
What oil do I need for this lower? Hi-Vis?
I honestly haven't even had to look at any other oils than the Type "C" as of yet, so I'm clueless on this one right now..
Ordering a manual tonight, but it'll take about a week to get here.
It's getting colder.. Going to do an impellor change and gear oil change probably before the manual gets here..
Hoping to get it out on my local lake once or twice before I have to "Winterize" it, and that's NOT too far away!
Thanks!!
