tschamp20
- Joined
- May 10, 2006
- 317
hey all,i have a bit of an issue after rebuild. the motor doesnt want to start w/o pouring some premix into the carbs. once i do it fires and runs great. what are the obvious things to troubleshoot. carbs have been rebuilt just prior to rebuild ,ran 3 times. wasnt able to do a thorough link n sync on test run,it was to choppy.but timing was right on according to manual specs at the proper rpm's. i did replace the fuel lines to carbs but reused a couple old oem clamps. fuel pump was replaced last year.
could it possibly be loose clamps causing low fuel pressure?
also noticed the new squeeze ball has a bit of a leak at the factory compression clamp.
what would you check? im trying to get my game plan for tomorrow.
thanks, Doug
thanks, Doug
