I've got a 2stroke 40 hp that I want to replace with a 4 stroke. The boat can plane (15' Livingstone V hull, not the twin hull) with the 2 stroke, and I want similar performance with the 4 stroke.
Is there a difference between power ratings for 2stroke vs 4 stroke, given the same HP rating? Like the difference between diesel and gas engines in trucks: same HP can give you very different 'power' (informal term so keep flames low!).
For example, can you generally replace 2stroike engines with lower/higher rating 4stroke HP rated engines to get same performance, or is HP = HP between the two?
Thanks
Flinch
Thanks
Flinch
