Kenneth Brown
- Joined
- Feb 3, 2003
- 3,481
Help me please! My "wild thing" has bit the dust. I know that this is a disposable saw but it has been a good one. Recently it has been a bear to start. After you finally got it running you would have to keep the throttle tapping so it wouldn't die. Once revved up it was great, no problems at all, till today. I fired it off and started cutting. I cut for about a minute and then it just stopped running. I think I pulled about ten muscles trying to get it to fire back up. No go. I brought it home and started the disassembly process. I puled the plug and cleaned it. Still no fire. I cleaned the magnets on the flywheel and the coil surfaces.I then used a drill to spin it over real fast and it started getting fire, but only very small spark. Put it all back together and its still no go. I then tryed the death spray (ether) since I figured it no longer mattered. Well, it didn't matter, still no go. Any ideas?
