76SeaRay
- Joined
- Aug 24, 2017
- 1,071
I am familiar with using pour foam having used it on hot tubs before and I understand the approach for drilling holes in the deck for the foam floatation then plugging them. However, it was pretty clear that the foam had swelled the floor when it was originally poured at the factory and the breakdown of the plugs on my boat was the method of water intrusion that got to the unprotected stringers. That said, I saw a Youtube video where they poured the foam without the deck installed then used a thin flat saw to trim the foam flush with the top of the stringers and ribs. After trimming they installed the decking so this way avoided holes in the deck. Is this method a valid approach that won't cause any problems?
Thanks.
Thanks.
