Power Head removal 115 6 cylinder
Fed up
I am looking to pull the powerhead on my Mariner and Mercury to swap transom brackets. My question is, Is there any type of gasket that I need to buy to go under the power head and on top of the mid section?
daveswaves
Ensign
Re: Power Head removal 115 6 cylinder
Yes, you can buy them at your local merc dealer or online here at I boats.
Fed up
Ok can you link me to all the gaskets that I will need to drop the lower unit and remove the power head.
I would like to buy most everything all in one shot so I can get this thing swapped over.
Thank you for your help.
daveswaves
Ensign
There is no gasket on the lower end. You will have to look up your gasket using your serial number, model etc. I'm just a member like you.
