Power in 1 plug
BigJoe
I have a 1975 115Hp evinrude I am showing power in only No2 spark plug the book says to put a No s80 Neon tester on it where can I get the tester or does any body have any ida what to check I had a new power pack installed about a month ago I hope its not it
Joe Reeves
Re: Power in 1 plug
BigJoe.... Remove the spark plugs. Rig up a spark tester whereas you can check each s/plug wire to see if the spark will jump a 7/16" gap.<br /><br />If, as you say, you do not have spark (or very weak spark), remove the black/yellow wire from the powerpack and retry the spark test. If you now have a good strong blue flame on all cylinders, you have either a faulty ignition switch or a short in the wiring harness.<br /><br />If with the black/yellow wire off, you had good spark, you can test the ignition switch by reconnecting the black/yellow wire to the powerpack, then removing that black/yellow wire at the back of the ignition switch, then recheck the spark. If you have spark, the switch is faulty. keep us informed.
BigJoe
Re: Power in 1 plug
Tnx Joe<br />What I did was I took a induction timing light and put it on each spark plug wire and only no2 cyl lights up the timing light no spark in any other cyln
almost retired again
Re: Power in 1 plug
Hi BigJoe,<br />Keep in mind that the batrery must spin the engine over really fast to develope a rear good spark. Engines in those years didn't start real good unless the battery was at full charge.<br />Follow Joe reeves advice first, but you can check the charge coil and sensor coil output with a peak reading voltmeter, or (I may catch some flak for this) a regular AC voltmeter. Multiply the reading that you get by 1.414 to get the peak value. I would suspect the charge coils should read approx. 145 V or better with a regular meter, and if the sensor coil voltages cause the meter to deflect I would say they are OK. I have used this method several times in the last 20 years when I didn't want to take my expensive meters to the water.<br /><br />Hope this is of some help
BigJoe
Re: Power in 1 plug
Hi Tnx with battery at full charge and blk and ylw wire off still no spark in any plugs but no 4 thought it was no 2 but was mistaken good spark in no 4 driving me NUTS ha
