Power Inverters
advertisingadmin
Administrator
<p>Inverter generators are perfect for boating, camping, RV travels, tailgating or other backup power needs. With these easy-to-transport portable generators, you can enjoy your electronics or small appliances with a quieter power solution compared to traditional camping generators.
<p><img SRC="http://www.iboats.com/mall_marketing/newsletter/may16/images/art1-1.jpg" border="0" />
<p>Inverter generators are a recent development and utilize a different type of alternator than standard generators to generate AC power. These are generally 3-phase generators that output AC current like most traditional generators, but that current is then converted to DC, and then "inverted" back to clean AC power. The raw power produced is converted from DC to AC power by a computer controlled inverter module. The inverter also smoothes and cleans the power to make it high quality. A special microprocessor controls the entire process, as well as the speed of the engine. The engine speed varies depending on the electrical demand, which significantly reduces noise and fuel consumption compared to a standard portable.
<ul>
<li><b>Smooth Backup Power</b> that's safe for sensitive electronics.</li>
<br />With the DC power being inverted back into clean AC power at the desired frequency and voltage, the system products consistent and reliable power independent of the engine speed. The result is clean power that is essentially the same quality you get from the electric company. Clean enough power to run even the most sensitive electronic equipment.
</ul>
<ul>
<li<b>Quiet Portable Generator</b> - Quieter than traditional camping generators.
<br />Since these units are designed to be quite with quiter engines, and sound dampening technology along with the characteristics of the engine to vary its speed when the load is light, make the invertor generator incredibly quiet.
</ul>
<p><img SRC="http://www.iboats.com/mall_marketing/newsletter/may16/images/art1-2.jpg" border="0" />
<ul>
<li><b>Light & Portable</b> - Small, Light and reliable
<br />Many of the new Invertor Generators are small, lightweight and are very reliable. With weights in the 40 to 60 pound range they are easy to transport and store.
</ul>
<p>The end result is a portable generator with reduced weight and size and power that is ultra-clean, capable of safely powering sensitive electronics.
<p>Click <a href="http://www.iboats.com/Portable-Generator-Sets-for-Sale/dm/view_id.1771733?cm_mmc=Email-_-May2016Review-_-ArticleLink-_-InverterGenerators">here</a> to find Portable Generator Sets at iboats.com.
