just a quick question - my boat is finally on the water and running amazing. The problem I am having now is with the power lift. When I go to lift the motor out of the water from full extension it will lift about an inch and stop, it makes the sound like the battery has no juice but it will be fully charged. If I lift the motor a little bit it will then start lifting and operate perfectly. It only gets stuck in the lowered position. Also, when I tilt the motor up in the water, as soon as I start moving it will fall down to the full lowered position.
