WallyMaster
- Joined
- Oct 9, 2007
- 17
I have a 1981 9.9 Marioner (the Japanese mariner model). Starts and idles great. When open up to full throttle, goes at full speed for about 15 seconds, then bogs and reduces to about 70% power. I have done the following and the problem still persists:
1. Got a new fuel tank, hose, bulb, and fuel hose connectors.
2. Replaced fuel pump diaphrams.
3. Suspecting possible overheating, I pulled the t-stat and tested it in a pot of water. Opens at about 150 degrees. So that's ok. Also, there is a good water stream out tell-tale.
4. Removed carb and cleaned it out with carb cleaner and compressed air. Checked float level and it was right on spec.
Last time out (after having done all of the above), when it started bogging, I pulled the choke out just a bit -- not all the way or it stalls... just out about about 1/4 inch. That did it. The power increased back to full speed. Clearly, then, there is some fuel starvation or excessive leaning-out. Since the fuel pump diaphrams and everything upstream of it have been replaced, I am suspecting a possible vacuum leak at or near the carb. Sound reasonable? if so, how would I check for that? Anything else it could be?
