stewfish1818
- Joined
- Jul 14, 2010
- 42
Can a power pack be intermittent on just two cylinders or did two coils go bad fouling just two plugs? If I change them it runs great and some time later I loose RPM. First problem I have ever had with her.
I'm thinking switch the coils with to others and see if the other plugs go bad or if it stays on the original two plugs.
Compression is fine, same as this spring time check.
Johnson 150
Model #: VJ150TXESB
Things I replaced, just to replace and make better.
New starter, Rebuilding old one to have on hand for emergencies.
Added a marine pro charger and second battery
Second bilge pump through-hull for redundancy
Changed throttle cable from 16' to 14' adjusted to set RPM good and adjusted throttle arm screw/bolts a little.
Stereo and speakers
Johnson 150
Model #: VJ150TXESB
Stereo and speakers
