I have a 77 merc 150 and have a problem with it dying after it has been running for 15 minutes, on the water, and it will not dye if it out of water in gear at 0r about 3 to 4 grand on tach. It will only do it when it has a load on it in the water.Can some one help me narrow this down to one thing.I know alittle about boat motors but not enough.What is the process to test the two. And what is the little box that the stator runs through. I know it has power to it when the key is on.<br />Can i use a multi tester for this?
