Just ordered a new power pack and it hasn't arrived yet. Reading the manual it states that you need special tool ({OMC insert tool p/n 322697}to remove and replace the stop switch wire Since i never hook up the stop lanyard can I just eliminate installing this wire if it becomes a problem getting it out and in ??<br />It also mentions that you have to line-up the crankshaft to allow sensor to clear wheel. Seems to me that it should come off when you remove the 2 bolts.<br />Evinrude 9.9 hp 4 stroke e10freleu
