Power pro Knot ?
rolmops
Re: Power pro Knot ?
Almost any knot will do as long as it is thin enough to easily run through the guides.Just make sure to use superglue on the knot so it will not slip.
JB
Uni-knot has always worked well for me.
Backlash
Uni-knot unless the diameter of the lines is pretty different...then use the albright.
AJ168
I like to tie two improved cinches, one on the braid, the other on the mono, through the loop I made with the first knot. It has yet to fail me and it only takes a few seconds to tie.
skimmer
I use a five turn surgeons, I find when done well it runs through the guides better than any other knot, works well braid to flouro too.
