I just picked up a 1998 Nitro and it has a Lowrance HDS-7 on the console. The boat has two batteries solely for the 24v trolling motor and a third battery for cranking and everything else.
When the engine is running down river, everything works fine. However, when you turn the big engine off and try to look at the fish finder it will power cycle randomly. If you try to turn on the livewell airetor, or any other electrical function, the lowrance will power cycle.
The battery is an Optima Blue top. No idea of age, but I threw a charger on there to test it and it says it's at 100%.
Basically, the lowrance works with the engine. With the engine off and NOTHING else electrical on, it will reset periodically and does it every time you turn something else on.
Any ideas here?
Thanks
Sam
Any ideas here?
Thanks
Sam
