power steering leaking at steering wheel
TxHorns
Power steering fluid is leaking from the big piece that my steerign wheel is attached to (the outside of my console). Does anybody have any ideas as to what this could be? is it just overfilled? It's been leaking for a little while now and I'd think if it was overfilled then it would have gotten to the right presure by now, but not sure. Thanks for the help.
pole position
Re: power steering leaking at steering wheel
You sure it's not hydraulic steering? Sounds like a small seal leak in the helm.
QuietRider21
I also have a leak at my helm..its been too cold to check it out yet. i'm not sure if thier rebuildable or not
TxHorns
my bad, yep, its hydraulic steering fluid.
cribber
What kind of boat do you have or what type of steering unit is it?
Ayuh,... You guys'll have to ID who's hydrualic steering you've got,...
Then, Hopefully, parts otta be as easy as Googlein'....
After that, all ya gotta do is install the seal, 'n bleed the system....;)
