96lt4c4
- Joined
- Jan 8, 2008
- 110
The last time I had the boat out it seemed like I had no power steering at all. So I figured the pump was bad. I put on a new pump. Yesterday after work I pulled the boat out of the garage and fired it up in the driveway. I made sure to prime the pump before I started it. Anyway, when turning the wheel to the left I get a shudder that is pretty noticeable, it will vibrate the whole dash. It will only do it while turning the wheel at a slow constant speed. If I try turning it faster it wont happen. Turning to the right is no problem. I am guessing the cable may be binding up while trying to push the drive and is fine when pulling drive? I have also read about the corrosion in the cable tube, I will check for that as well. Any other Ideas? I just hope the rack and pinion is not bad.
