andrewterri
- Joined
- Jun 25, 2014
- 437
Boat is a 2014 Monterey 196ms with a 4.3 MPI ECT. I have been trying to diagnose a hard steering issue. I do not have the manual as mercruiser somehow only gave the original owner a manufacture installation cd. When I called Mercury to ask about this they said they will mail me a owners manual since the boat did not come with one and that cd should not have been given to the owner. I also ordered a shop manual from mercury for the engine and drive. Problem is I'm trying to figure out why the steering is so hard without having a reference to how it is set up. Looks just like the old 3.0 we had and trying to use that as a starting point for troubleshooting. while at the lake on the maiden voyage, the steering acts like there is very little assistance from the power steering pump. when I run at speed it feels a little bit easier. My thought is the pump and higher rpm is spinning the pump faster which is increasing pressure. While it appears easy to get a new pump and just install it into the reservoir I do not want to start guessing as this can get very expensive and time consuming. Does anyone know how to test the pump to see if it is the pump or steering cable? Are there lube points for the steering assembly that might account for my problem? I have looked and everything is covered with wiring harnesses and hoses that I can not see anything obvious. As always, that you guys for taking your time to help me.
