I have a 1984 Mercruiser sterndrive with 300 hours on it. The boat was in storage for 10 years. The engine and stern drive were serviced and run fine, but now I have a problem with the power steering. First 10 minute test run, power steering was slightly stiff but worked fine. Second test run (next day) the power steering became increasingly stiff within minutes and took extreme manual effort to move the steering wheel. The more I moved the wheel, the tighter the steering became. I suspect the actuator is fouled or corroded, can I take it apart and clean it? Can the steering cylinder be taken apart and cleaned? What else do I need to check? The cable is in good condition, pump has fluid, there are no leaks.
