power tilt and trim 1986 vro v6 evinrude 225 leaks
express246
I recently lowered my motor and didnt realize the 2 metal peices used for trailering were extended in the trailering position. when the motor lowered ,the 2 pieces were stopped by the tilt motor and resevoir apparently breaking the seal. when I examined the motor and resevoir I noticed that they were leaking in the down position. the resevoir is leaking approx 1 drop every 10 seconds,and the motor 1drop every 30 sec. They are both leaking from where they attach to the main unit. Is there a way to slow down the leak without replacing the o ring or the motor and resevoir?
SpinnerBait_Nut
Re: power tilt and trim 1986 vro v6 evinrude 225 leaks
Welcome to iboats express246.
This forum is for forum issues only.
I will move this to the Johnson/Evinrude repair forum for your answers.
