I hope I posted this in the right place.But the question I have is I own a 1984 Johnson 90 hp and I was wondering is there fluid in the power tilt and trim unit on this motor that needs changing and or checking..If so where and how do you check and or change the fluid?<br /> Also I changed the lower unit fluid this morning and filled it until it came out the top vent, I kept pumping a few more times to get a good solid flow to get all air pockets out, but when I went to disconnect the pump from the bottom some fluid escaped before I could get the screw back in,not to much just some.But when I take the vent screw out on the top to check no oil comes out,I added 1 more time to make sure it was full and got the screw in quicker this time. I guess what I am asking is it ok if when you pull the vent screw that oil doesnt come out or do I need to add more?<br /> Thank you in advance.
