Re: power tilt question
I'm with upinsmoke. A bad battery may appear to be good, but it is not necessarily true even though it holds 12 amps. The bigger truth behind a bad battery is the length of time that it is able to hold that charge.<br /><br />If you had bad wiring that caused a good battery to drain in a matter of a few seconds, you may also be finding some smoking insulation on your wires.<br /><br />John
