Re: Power tilt schematic ( 1967 )
Anyone understanding what I was trying to draw ?<br /><br />To help you understand why , the electric wiring was rely bad ,+ someone have tried to repair something inside the electric motor before I got it , they did some soldering but it did not hold .<br /><br />When I opened the head I found :<br />Green wire soldered to field coil 1<br />Blue wire soldered to field coil 2<br />Output on bout field coils were connected together ( center field coils , see pic )<br />So far so good , all these soldering looks original<br /><br />But the brown wire from the center field coils to the brush ( point 2 on the picture )<br />And the black wire connected to the "overheat ? " switch ? , this one was loose( point 1 on the picture )<br /><br />So the simple question ,where do I connect the BLACK and the BROWN wire
<br /><br />Got it running , but without any "overheat" switch ,and the black wire NOT connected to ground ( used the metal as ground )
