A johnson (Model #115TLCNB Serial # J5691817) The moter will tilt all the way up but will not tilt back down. It hold the tilit up position without the travel stops engaged. While trying to figure out what was going on when I got home I noticed a leak on the fitting that goes onto center lifting cylinder this fitting has a few coils before it enters the other cylinder. I pulled the line off and noticed that it had o-rings on each end I am guessing that one is bad but I have never had oild on the floor with the motor tilted down. Do you think this is the problem I hear the motor run in both up/down. My big Question is in What position is the motor when refilling the cylinder full up or down and does the system have to bleed somehow. Thanks
