I've been reading up on how to refill my power tilt and trim and yes it does make sense but here's my issue.
I loosened off the manual refief srcew so I can lift my motor. Once I got power I tightened the srew and noticed oil dripping out. I cut the O-ring from loosening off to much. I replaced the O-ring and well to make a long story short I didn't tighten up the screw, tilted the motor and all the oil shot out.
I am trying to add new oil but the center piston will not lock up. Its like the releif screw is loose (but its tight). I've manually lifted the motor up and down tons of times. I hear oil pushing the air but were does it go? I've also keep adding oil until it runs out the fill hole. I don't see any oil leaking from the piston.
Anyone have any Idea??
