Power tilt
joita
Hello,
I have an alpha 1 gen 2 out drive 1998. I changed the bellows, hoses,shift cable, trim sender and the limit switch. All went well until I trimmed up the out drive,it went down and when I trimmed down it went up. I did not adjust the switches yet but could the trim sender be the problem? I attached all the wires to the right places( they are made to attach to the right places).
Bt Doctur
Re: Power tilt
you had to reverse the wiring or the hyd hoses.simply replacing the TL dosent do that. Only other way is to have the battery cables reversed at the battery.
