have voltage going to motor via blue or green when switch is pressed. Trim motor has continuity (ground)to main engine block. Have replaced both relays. Trim motor is only two weeks old. No tilt either way problem started as intermitant but now has quit all together. What can cause the motor not to run either way if I have the voltage?
