How should I fill this up with the motor down or all the way up? Thanks.......
S strat751 Cadet Joined Apr 30, 2003 Messages 19 May 8, 2003 #1 How should I fill this up with the motor down or all the way up? Thanks.......
C chris in va Chief Petty Officer Joined May 4, 2003 Messages 410 May 8, 2003 #2 Re: Power trim and tilt fluid? My shop manual for the Volvo SX says for it to be trimmed all the way up, otherwise fluid will spray everywhere.
roscoe Supreme Mariner Joined Oct 30, 2002 Messages 21,854 May 8, 2003 #3 Re: Power trim and tilt fluid? It depends on the motor, trim unit and age.<br />My 1995 Force 70hp is filled in the DOWN position, using 30wt motor oil.<br /><br />Dad's Merc is filled in the UP position, with ATF.
C chris in va Chief Petty Officer Joined May 4, 2003 Messages 410 May 8, 2003 #4 Re: Power trim and tilt fluid? Wow...that's interesting. Motor oil?
J Jack Shellac Lieutenant Commander Joined Aug 7, 2002 Messages 1,661 May 8, 2003 #5 Re: Power trim and tilt fluid? OMC's are filled in the UP position and cycled at least 5 times to get rid of air, refilling as necessary. With PT&T fluid or Dexron 2 ATF.
