Striper500
- Joined
- Nov 20, 2005
- 52
I have a 1995 130hp Johnson with power trim and tilt. If the motor is lifted all the way up, it will ever so slowly go down. I filled the resevoir with fluid this weekend and worked the motor up and down a number of times to purge the air. This didn't seem to be the problem. I also used soapy water around all of the seals to see if there were any air leaks and didn't notice anything. Is there anything else I should be checking ? any common items that normally go ?
