Power trim and tilt
suttonc
After turning the manual release motor on my 225 Johnson, should the motor move? It is stuck in the half way up position. Does this sound like it is out of fluid? Please let me know what you guys think.
rickdb1boat
Re: Power trim and tilt
Yes, if you unscrew the proper screw,(Manual Release), it should drop down. You would need to get the Motor to the "Full Tilt" position to check the fluid, but that should not keep it from coming down. What happend when the Trim failed?
