Stan's Customs
- Joined
- Oct 30, 2004
- 161
After our first lake test run on this 1988 Four Winns, all shift linkage adjustments seem to work well..in fact better than I expected after the clunky shifting on muffs. Shifts very smooth really, which is good news.<br /><br />The carburetor has just been rebuilt and performs goog out of the hole, idles well etc....there is a problem though. At 3500 RPM or more the engine doesn't seem to make power like it should. It even popped back once or twice at full throttle, though only once or twice.. I think the carb is OK...thought that maybe the valve springs might be a little weak for full throttle RPM. I changed my mind about that when I noticed that the RPM's were affected when I trimmed the drive up and down. Loss of power if you will. Ignition interrupter malfunction maybe... I'm not sure. It doesn't seem like the trim could be related to much that could cause a power loss, any ideas?? Whatever it is I imagine it has something to do with the higher rpm fluctuation when over 3500 as well.<br /><br />If anyone has ever heard of this happening on a boat before I'd sure like to know what the cause was ...or any other suggestions as to what may be the problem area. <br /><br />Thanks...Stan
