I posted a question on this and should not have combined it with an unrelated question, so this is a follow up to the same issue, by itself. This is a great site and I get a lot from it.
OKAY, the down function on my tilt/trim is spotty and inconsistent, sometimes taking a few pushes of the button before the motor lets the engine down. Same problem no matter which button I use.
I pulled the relays, and the sockets are good, and receiving current. I'll check the relays, themselves, and ohms today. It would seem, however, that a bad relay would always be bad, not just sometime.
My manual suggests removing the blue/green wires at the pump housing. There isn't much room, but I suppose I'll manage. What am I looking for there? Frayed wires?
The "up" function works perfectly.
I'm going to the lake, no excuses this time. Can I assume that if for some crazy reason my motor won't lower that I could loosen the manual relief valve and get hooked back up to my trailer?
Thanks again for all the help.
