Jims invader
- Joined
- Sep 3, 2016
- 7
Was checking trim fluid on my boat I recently bought and I'm a confused after reading some of the forums on what to add for trim fluid. I have a Mercruiser set up and after checking the fluid I can't determine what fluid is in there. It is not atf or motor oil. It is clear in color and has a smell similar to paint thinner but not as strong. It isn't as thick as oil either. Trim works fine and has no leaks. Is it possible this is hydraulic fluid and if so. What type should I use??
