wcsd106
- Joined
- Mar 27, 2010
- 182
I recently bought a new (to me) boat with a 1986 Mariner 115 Inline 6 cylinder outboard. The previous owner stated he had installed a new power trim motor, but that he believed there was air trapped inside it. I believe most of these systems are self-bleeding, but I know a lot of the time people do not get them filled completely. However, I've been working with it most of the afternoon and am getting no closer to a solution. I am beginning to wonder if the pump itself (not the electric motor) may have some issues. Please read what I've observed.
Here are the symptoms I'm seeing:
This afternoon I was by myself so I was unable to see the trim cylinder during up/down movement to see if any fluid was leaking out of the cylinder. I will try and get a video tomorrow to better show what I'm dealing with. I have also attached two pictures of my power trim pump for identification purposes.
I'd greatly appreciate any help that can be provided. Thank You.
- Power Trim Motor runs and sounds strong on both UP and DOWN cycles
- As outboard is trimming up or down it will occasionally stall and the motor will seem to rev and get louder.
- Sometimes the stall will clear itself and the outboard will resume its movement. Other times you must stop the power trim motor and then start it back up.
- The outboard will trim completely up, but it is VERY slow to do so. I get more instances of the stalling on the up cycle than on the down
- At full up or full down the motor sounds like it is running dry and trying to suck in more fluid.
- After a few cycles, if I bring the outboard all the way up and open the power trim fluid fill neck I sometimes see tiny bubbles in the fluid
- After a few cycles, the trim fluid level will be lower. I refill and then begin running up/down but I never seem to get all of the air out
- I have used one complete tube of power trim fluid and part of a second but the problem is not getting any better.
