power trim not working
wdknox
I have a 1989 mariner 50hp motor. How do I lift the motor to get to the power trim motor.
ob1jeeper
Re: power trim not working
In both the Seloc, and Clymer manuals for your motor, are instructions on how to do this... Don't have the exact location off the top of my head, but you will most likely find a "manual" bleed screw identified in the manuals, which you can open to release the fluid pressure on the ram piston, then manually lift the gear case until you can set the latch to hold it up...
wdknox
Thanks for the info. I don't have a manual but just looking at it I think I know where to bleed it off.
