Power Trim Problem
Procraft
I have a 150 Mariner Mag 3 and the last time I was out the power trim would not go up past about 3/4 while running full speed. At slow speeds it works fine and on the trailer it raises to the full up position, any ideas ???? Thanks V.R.
ob
Re: Power Trim Problem
any leaks at servo? probably weak pump if not.tremendous down forces on motor when running at WOT
Reel Appeal
Why are you trying to tilt past 3/4up while running wide open anyway.Are you trying to create a rooster tail? :confused:
